I have a new installation of Megarevo R8KLNA. I have 10.2kw of QCell 425watt panels ground mounted in 4 serial strings coming into the inverter. The system is off-grid. I have four 10kwh GSL 48v Lithium "powerwalls". I know there is a 12amp current limit for the inverter from each of the 4 strings, but being serial wired, they should deliver 10.2amp in a perfect situation.
Currently, when I try to run my clothes dryer, the inverter will shut down with an over current error. This has happened 4 times and each time, there is no other large appliance running. Typically, just fridge, freezer and maybe a few LED lights (sometimes not even that).
When it gives this error, it is never pulling from the batteries. Yesterday there was zero current being pulled from any of the 4 batteries.
I am able to restart the inverter and then it will handle the load and not give me the error again. But, every other time, when I start up the dryer, except for twice (which was ironically after dark, so it had to use battery power), it shuts down with an over current error.
Anyone else experience anything like this or have any insight? The GSL support staff points me to the Grid Output limits and tries to explain to me I can only run a load of 38.8amp, but I know this isn't true. And, I'm not on grid anyway. I've pulled 80amps at a time, using small appliances around the house.
Screenshot is of the 4 PVs at the time my clothes were drying, just after it shut down. It doesn't' look right, because it should be pulling more current from the panels than this, but this is about the most it ever pulls.
