I'm building a small system that will handle about 120w of continuous AC load in the house.
I've got 2 x 450W LONGI Panels:
And want to get the 60A MPPT Renogy Charge Controller 12-48V (Max PV input 150VDC, Max PV Power input only 800w for 12V, 1600w using 24V) with the Renogy 2000w Inverter, using 2 x 100ah batteries.
It looks like, from the Inverter, that I need to configure the Panels in Series.
Would the panels need a fuse/breaker?
Should I get a 100amp fuse for each battery?
Thanks for your help.
