Looking to build simple and cheap 5kWh, 48v dolly cart mounted all in one. I have my 48V battery already, Just need to find an all in one inverter charger and cart.
Which do you suggest between the two?
Renogy Rover 100 $719
www.renogy.com
ROVER 100 AMP MPPT SOLAR CHARGE CONTROLLER $719
Nominal Voltage: 12V/24V/36V/48V Auto Recognition (for non-lithium batteries)
Rated Charge Current: 100A
Max. PV Input Power: 1300W/12V; 2600W/24V; 3900W/36V; 5200W/48V
Max. PV Input Voltage: 150VDC (25°C), 140VDC(-25°C)
Self-Consumption: 2.7W - 2.9W
Operating Temperature: -35°C to +45°C
Temperature Compensation: -3mV/°C/2V (default)
Dimensions: 12.00 x 17.44 x 4.35 in
Weight: 22 lb.
Enclosure: IP32
Terminals: 25mm2, 4AWG
Certification: CE
Bluetooth: Renogy BT-1 & BT-2 Bluetooth module
Accessories: 2-year material warranty
EG4 3kW $675
Features:
Rated Power:3,000WMax Battery Voltage:
![www.renogy.com](https://cdn11.bigcommerce.com/s-fhnch/products/1904/images/24396/100A__82094.1709539201.500.750.jpg?c=2)
Rover 100 Amp MPPT Solar Charge Controller & BT-1 & Renogy ONE Core
Renogy Rover 100 Amp MPPT Solar Charge Controller making it great for RVs, caravans, and boats. With its advanced MPPT charging technology, your batteries will be protected from discharging and over-charging. Free Shipping!
![www.renogy.com](https://cdn11.bigcommerce.com/s-fhnch/product_images/Group.png?t=1667469334)
Weight: 22 lb.
Enclosure: IP32
Certification: CE
EG4 3kW $675
Features:
- 3000W Continuous Output Rated AC Output Power:120V
- PV Input: 5000W
- MPPT Operating Voltage: 500VDC max input
- 48VMax Charging Current: 80AMax
- Parallel up to 12 Units for a 36kW System
- BMS Communication Available With All EG4 Batteries
- Upgraded Active Cooling & Circuit Components(When compared to competing models)
- Lightweight
- Smaller Footprint Than Other Comparable Models
- Overload Protection
- Overtemperature Protection
- Short Circuit Protection
- User Customization via LCD Display
- 3-Year Warranty Supported and serviced out of Texas
- Larger Battery Terminal Connections(Supports up to 2 AWG)
- Minor Improvements to the exterior design
- Fully compatible with V1 units
- BONUS KIT INCLUDED ($149 value)
- Wifi Stick with Remote Settings Adjustment
- 125A UL listed Nader Breaker and Din Bracket
- 6Ft 4 AWG Red and Black Battery Cables
