No but I can put it on there. From what while we said, I thought using the DMM would be more accurate. I’ll hook it up.
So far this seem ok. I might not leave it unattended overnight in case something unexpected happens, but as long as you did not adjust the voltage on the power supply after connecting it should be fine. It is normal for it to take a very long time if the battery is not nearly full alreadyUpdate: first battery charged to 13.8 in just over 24 hrs. Second has been charging but stuck here(picture) or near here for most of the day. Will leave it overnight and see tomorrow. This was the battery that I had mistakenly connected pos to neg when hooking up two in parallel. Hope I didn’t fry it. The DMM reads 13.6
I’m not sure. Do you mean how long did I charge it for? This morning it was charged to 14.4. When I read after disconnecting, it dropped to 14.2So far it looks like your prior charger just wasn't up to the task of charging these batteries.
What is the total amount of Ah you've input into battery #2?
Right. Figured that out after I disconnect the meter. Oops. Now reads 14.1 on DMMNo. That was the purpose of the battery monitor - see how much you put into the battery.
Thanks, me too! Can you you explain to me like I’m a two year old, how to do a discharge test? I read the earlier post three times but can’t follow it.No worries--It'll still be useful for measuring the capacity of your batteries as you discharge them. Although it certainly would've been interesting to have known how much energy you were able to dump in.
I was using a Battleborn 100ah in my 5th wheel a few years ago, and never really could get it to charge well off the built-in WFCO "converter". If I put a good load on it, it'd drop the voltage down enough that the WFCO would put out max current for a while. But lead acid battery chargers don't want to destroy the battery by over-charging, and that means the the so-called "drop-in" LiFePos just don't get fully charged, and over time, become unbalanced. In my case, I had a Victron MPPT charging it according to the recommended settings, on sunny days at least.
With any luck, your issue is/was just unbalanced cells. Hoping to hear good news once you've completed the discharge test!
Does the charger ever get to zero? I’ve seen mine get to .017 current but not lower. This battery is at .054.Important note. DO NOT trust the voltage reading from the battery meter for charging purposes. It might be as much as 200mv off, which makes a difference. To measure BATTERY voltage, use a DMM directly on the battery. To measure charger voltage, use a DMM directly on the power supply. These readings will sometimes not be the same. And never adjust the power supply when it is connected. Disconnect, adjust, then reconnect.
No, it will never reach zero. It will get close, then stop going down.Does the charger ever get to zero? I’ve seen mine get to .017 current but not lower. This battery is at .054.
I have two 4 amp batterytender with lithium settings … I used them back in 2020 to charge my 12v lithium batts while I bought other stuff to build a system..I had a voltmeter hooked to them while the charging occurred about every 3 month…I am suspect of any charger that has an LFP setting, but doesn't tell you or let you adjust what that is. Many cheaper chargers that claim compatibility with LFP will change to LFP voltages (14.4-14.7) but NOT change absorption times or tail-current, or float voltages. These chargers will charge LFP batteries, but over time will damage them and reduce their capacity.
I have not tested the Battery Tender to know one way or another. But they don't seem to publish this information, and conceptually, what the battery tender is (a battery maintainer) is a function that is needed for Lead-Acid, but damaging to LFP.
Further diagnostic requires a charger where you can specifically set the voltage, absorption time, and measure current.
I do not understand how so many newbies come on here , cop an attitude and want to argue their case with pros who know 100x what they know….Using a multimeter, while witnessing the battery icon on the MT50 showing full battery and 13.8v, the multimeter also read the same, within .05 volts. Every so often, the MT50 would report a spike in battery voltage to 15-16v and then it would abruptly drop to 12.5 and stay there for a while before returning to somewhere between 13 and 13.8 volts.
