I was considering the JK B2A8S20P for my 24v LF280K batteries in which I would have two banks wired in parallel. However, I saw in one of Off Grid Garage videos (8 months old) that these are not compatible for use in parallel battery banks. I sent an email to Jikong Technology to verify this as it is not mentioned on AliExpress. No response.
I'm wondering if the reason might have to do with it being a "smart" BMS that has the active balancing? I'm looking for two 24v 8s capable of at least 200 continuous amps to be used in parallel. It does not have to have active balancing, it just seemed like a good idea. Anyone know for sure whether active balancing would be the reason a BMS would not be compatible with parallel configs? Or, is there something else I need to be looking at to determine if a BMS would work for my configuration?
Thanks.
Thanks.
