MartyGras
- Nov 23, 2019
- 14
I have a 24 V battery and a Daly bms
When I check the voltage from one end of the battery to the other I get 27.1 V
when I short out the negative cables off the BMS and then plug in the balance leads it starts out at 27.1 V and then the voltage continues to drop until it reaches the 14 v range, if I check the voltage is the battery it’s still 27.1 V
I double check the continuity of every BMS lead and everything seems to be connected properly...... shut out the negative leads against each other and again it goes back to 27.1 V and then gradually drops
what am I missing here?
Thanks Gary
Thanks Gary
