wstcoaster07
- May 16, 2020
- 14
I recently built a 12v LIFEPO4 battery with 4 3.2v CALB cells from AliExpress and the BMD from Overkill (basically the Will Prowse DIY 12v battery). I discharged the battery to zero during a capacity test and then hooked it up to my charge converter (Progressive Dynamics PD9160ALV) and watched it go. The XiaoXiang app correclty showed the current going in to the battery and the voltage of each cell. It reached "100ah" on the app a little early based on the current going in (60 amps/hr) and time it took (1hr+15min), but I assume it was just showing 100AH and 100% because the voltage had reached 3.4 per cell. (? correct)
Anyway, it kept charging as I assumed it would since I knew 100AH had not actually gone in to the battery. At around the 1+40 mark the cells were now starting to climb in voltage and showing 3.53-3.59. Also, the current going in had slowly started to drop from 60 down to about 20amps until the BMS shut down due to over voltage of one of the cells hitting 3.65.
I assume the BMS was doing what it had to do because the battery had hit full charge. But once it did that, the tracking of "remaining capacity" in the app went from 100 (after slowly climbing during the charge cycle) to zero. It looks like the BMS now doesn't know the power that is currently residing in the battery, which I assumed it should track.
1) I had assumed with the BMS and the app, I could track power going in to as well as out of the battery, and the app would tell me how much "life" was left in the battery at all times. Is that not true?
2) If it SHOULD track this, how do I prevent it from erasing the data once a full charge is attained and the BMS cuts off charging due to one of the cells hitting the over voltage at 3.65?
3) 100 AH went in to the battery, yet an hour after I removed the charge converter the cells seem to be resting around 3.35v which also seems wrong. Is this correct or could something be set up wrong?
4) I have done a full charge and a full discharge cycle of the system, so I have confirmed that I have 100-105AH in the batteries, so I feel like it's either a BMS hardware or software issue / charge converter issue / or just a lack of understanding and what I am seeing is normal.
Thank you for any help you can provide.
