First of all, I apologize for this long entry, but I want you to clearly understand my whole system situation, and therefore my questions. And I want to THANK YOU so very much for any help you can give me about how this system can work!
I have 2 12K’s in tandem. I have 30 kWh battery bank from Signature Solar feeding both 12K’s. At the moment the grid feeds through a main disconnect to the main electrical panel then to the 12K’s grid connections. Then the 12K’s load connections feed directly to the main panel. That way Solar can serve the total home needs, and feed excess back to the grid to completely eliminate our electrical bill through net metering.
However, when we had a power outage, the 12K’s disconnected the solar, and the battery bank did not serve as a backup for us. So I have some questions.
If I connect the grid first to the grid connections on the 12K’s, and then, connect their load connections directly to the main panel, if we have another power outage, will the 12K’s automatically disconnect from the grid so I don’t electrocute those working on the grid, but will the also 1. Allow the solar to continue working, and 2. Allow the battery bank to back up to supply our electrical needs through our main panel?
When I look at the wiring diagram for 2 - 12K’s, it shows the grid feeding to both 12K’s, and at the same time, to a 200A Bypass Manual Transfer Switch to the main electrical panel. The 12K’s load connections also feed through the 200A Bypass Manual Transfer Switch to the main electrical panel. However, it appears to be an “either/or“ situation. The grid can feed through the 12K’s AND the 200A Bypass Manual Transfer Switch to the main electrical panel, OR, through the 12K’s load connections through the 200A Bypass Manual Transfer Switch to the main electrical panel. If the 200A Bypass Manual Transfer Switch is switched to go directly from the grid to the main electrical panel, I’m not understanding how the solar system can feed our excess solar production back to the grid for credit through our net metering arrangement. Or, if the 200A Bypass Manual Transfer Switch is switched to go from the 12K’s load connections to the main electrical panel then we can feed our excess solar production back to the grid for credit through our net metering arrangement. But if that’s the case, why do we need the 200A Bypass Manual Transfer Switch?
When I look at the wiring diagram for the 15K, it shows wiring without the 200A Bypass Manual Transfer Switch, with the 15K load connection feeding directly to the main electrical panel. No 200A Bypass Manual Transfer Switch needed. However, it also shows another wiring diagram for the 15K, and it shows wiring WITH the 200A Bypass Manual Transfer Switch feeding directly to the main electrical panel, like the 2 - 12K wiring diagram.
So I’m confused. Since it appears that the 15K can work with or without the 200A Bypass Manual Transfer Switch, Is the 200A Bypass Manual Transfer Switch necessary with my 2 - 12K setup? Or, with my 2 - 12K’s, can I use the same wiring arrangement that the 15K uses without the 200A Bypass Manual Transfer Switch? And if I do wire it like the 15K diagram without the 200A Bypass Manual Transfer Switch, Will I then be able to have the credit for our excess solar production through our net metering arrangement? And just as important, if we have a power outage, Will our solar production work, and Will our battery backup work?
THANK YOU SO VERY MUCH for any help you can give me!
