That would work great. Home Depot Unistrut with the spring bolts and square washers to hold the panels is what I used. Unistrut is amazing. If mounting to a roof and you dont want it to leak, use quickbolts with their micro flashing.I'm in a similar situation. Wanting to mount 6 415w panels on my shed roof. Current plan is to go pick up some 41mm steel channel strut and some spring nuts and bolts from the local electrical wholesaler. Going to work out a lot cheaper than the "proper" solar mounting systems.
Thank you!!!If you just have 4 panels, Tamarack has a kit that includes everything you need in a box that can ship UPS. There is a dealer locator on their web site.
Roof Mounting System | Tamarack Solar Products
SIMPLE AND ECONOMICAL Flush Mount (FM) Roof Mount System Offering the first major improvement in railed system technology in many years. Single tool installation is straightforward and extremely intuitive. The two rail profiled (heights) available to meet various snow and wind ratings. Rails...tamaracksolar.com
oh wow, thank you!I went with the K2 system for my shed it was really well-designed IMO. K2 mount to attach the rail to the roof comes with thick membrane when you screw it down to the roof it really seals it good. The rail was k2 86 inch 44-X. The clamps slide into the rail are designed for residential panels they clamp down get one clamps two panels in the middle. End clamps go on the ends of the panels. Two 7-foot rails roof mounts, and the slide in clamps I spent about $65. This video below shows the L brackets to mount to a steel frame I used the larger T bracket it is can splice two rails together end to end.
Can the K2 be mounted on shingle roofs?I also did the K2. Pretty simple install with plenty of adjustment. I did 4 runs of 60' for two rows of 16, strings of 8. It was a little pricey, but I'm glad i went with a decent rail system. Mounting the rails and panels was really easy.
Any particular Tamarack rails/mounts?Big fan of Tamarack rails / mounts for my first 2 roof arrays. I'll be using unistrut for the ground mount.
I think they only make 2 versions.Any particular Tamarack rails/mounts?
make your own kit? Any recommendations?I think they only make 2 versions.
I bought mine from NAZ, now just solar electric.
If you order the shorter version they ship ups, I also found it cheaper to make my own kit vs purchasing the pre made.
Any recommended sites to buy the k2 rail system from?I went with the K2 system for my shed it was really well-designed IMO. K2 mount to attach the rail to the roof comes with thick membrane when you screw it down to the roof it really seals it good. The rail was k2 86 inch 44-X. The clamps slide into the rail are designed for residential panels they clamp down get one clamps two panels in the middle. End clamps go on the ends of the panels. Two 7-foot rails roof mounts, and the slide in clamps I spent about $65. This video below shows the L brackets to mount to a steel frame I used the larger T bracket it is can splice two rails together end to end.
I meant I ordered the Tamarack components I needed separately instead of the pre-made kit they sell...make your own kit? Any recommendations?
cool. Thank youI thought putting the Tamarack kit together was pretty easy. And Tamarack now offers add on kits for their prepackaged racks so you can easily add a couple more panels to a 4 or 8 panel rack without having to buy another whole kit. And NAZ has all of the clamps and rails individually if you need to customize the kit some more. I ordered extra mid clamps.
great! Appreciate it!IronRidge XR series, best free online design tools, listed, leak proof mounting
Ah, lol. Got it!I meant I ordered the Tamarack components I needed separately instead of the pre-made kit they sell...
I might buy individual components. Looking to mount 4 panels at most on my garage. Can you provide me with a list of components that one would typically need to mount? So confusing...lol.I meant I ordered the Tamarack components I needed separately instead of the pre-made kit they sell...
... The same items that come in the kit except the microinverter mounts... You need rails, rail mounts, end and mid clamps, grounding, etc.I might buy individual components. Looking to mount 4 panels at most on my garage. Can you provide me with a list of components that one would typically need to mount? So confusing...lol.
