MikeSpeegle
Yes they are valwood 12.6 x 250ah. And are designed to be in 2p/4s etc. each has 200amp BMS with all the normal stuff included Bluetooth and low temp shut off but I. Texas that’s like 5 days a year on low temp.I doubt the PowMr is listed for grid tie (and no hybrid on the market will be with those batteries) and it seems scary/risky to combine 12V batteries in a size big enough for a house. Did you at least verify that the 12v BMS is tolerant of being built into a 48v pack?
You will need to keep using the SE unless you remove the optimizers and replace them with RSD. Forget any discussion out there about the compatibility stuff from SE like unlock Key, they don’t provide it anymore.
Valwood has certified the setup with this configuration using 2P/4s or 3P/4s if I get the last 4 batteries with the powrMr hybrid split phase inverter.
Also it will grid tie or generator tie off grid.
The SE only used 7.6 kWh of my panels. I will remove the optimizers and put 20 to each of the charge controllers in the PowrMr
