Those large panels must have been a real bear to handle. Original post appears to show just roofing on metal frame, no plywood. How did you get around on the roof to mount them without stepping through unsupported areas? I was thinking nails into plywood, but given the frame structure, I can see how vertical not horizontal rails clamped at frame would be strongest.
