A Tesla Megapack will run you about $400/kWh before the IRA incentives and is 3.6-4MWh with inverters integrated in a ~26' shipping container. There are smaller competitors (at least in terms of mindshare) that should be less capital outlay. I would also see if your utility has any grant money available for energy storage. Not to sound like a broken record, but the best time/value you will spend is talking with your utility, the problems you face, and finding ways that you can solve your problems for mutual benefit.What battery types are available at 1-2 MWh of capacity?
Is there anything available, beside LiFePo (very expensive), on the market that's more economical but has comparable discharge and charge efficiency number?
Whatever you decide, please do report back here though!
How much are you paying per kWh ? How many motors and power rating of each? It may be cheaper to buy VFD for each motor so phase voltage misbalance will no longer be an issue.The location in question is serviced by a poorly run electric company and we've found that the legs are very often out of balance, especially during the summer months, which is destroying the life of our motors and electrical equipment.
See if you can find an account representative or senior planning engineer, FWIW. Indicate that power quality is bad enough that you are prepared to move off grid if your system reliability cannot be improved. If it doesn't work... time to get off grid.I have, multiple times, over the years. ...
rocks on rail carts?AZ - maybe water is not an ideal solution.
I was told that a 300 kW propane generator burns 9 gallons per hour at full load, so I interpolated that a 500 kW pro. gen. burns about 15 gallons per hour at full load. Assuming we run it 12 hours a day, 365 days a year, and that propane costs about $4/gallon, I got $263K, which is still a lot of money.
I like this option, but unfortunately, I believe our utility has both generation capacity (they buy all their power from others and are still short) and distribution capacity issues.
Sol-ark makes a 60k 3-phase unit. You can parallel up to 12 for 720kW. Maybe make two 540kW plants and divide your site.
Don't know how to make 800v battery for it. If you can, charge the batteries from the grid, and it gives you a double conversion UPS to clean up grid power, and reduce cost of generators to stand-by.
You need enough batteries to store the solar produced during the day for use during the other 24 hours. Commercial net metering is probably much worse than residential. You can do a cost/benefit of storing solar vs running off grid (via double conversion) to optimize battery sizing. You can always add more bateries.batteries. BTW, you are looking at 1,200 amps at 800v to produce 1mW. I think you are looking at 1,200 LF300 cells per hour of storage. About $180,000
I have thought of this. I know a very good working system, but I'd need a mountain to store water at elevation.ESS for a 1MW system!...need a couple of lakes close together with a thousand feet of elevation difference between them.
Solar pumps water to upper lake, hydro turbine(s) create the power needed.
Who is John Galt?That power company seems flaky and some may be leaving a sinking ship. There’s the possibility that the company model is to take the income and distribute it as wages without any consideration for maintenance or upgrades. When the system totally collapses, the phone won’t answer and you’ll find the office door ajar with not a soul in sight, corporation records gone. Ran into the ground. Personally I’d take care of yourself with an off grid solution because if I’m right it’ll be a long time till your community has reliable power again.
Hello all,
I hope this is the right subforum to post this thread in; discussion includes generators, solar panels, and large-scale inverters.
I'm looking into the feasibility of building a 1 MW power station and using grid power as backup.
I'd like to get a ballpark figure on costs before spending too much time digging deeper.
Our current power consumption is about 700-800 KW at peak, and our annual electric costs are about $225K.
I've estimated that if capital costs of such a system can be repaid in 10 years, including generator fuel, it's worth the investment.
My initial thought is to buy 1 MW of solar panels (day) and 1 MW of propane generators (night).
Ideally, we'd have 3x 500 KW generators, 2x running in parallel simultaneously and 1x shut down for service (or as a backup) at any time.
I have not even begun searching for inverters of this size yet, and this is one of my main concerns.
Adding lithium batteries at this time seems prohibitive, unless someone has a good, economical storage alternative to propose.
Any thoughts, input, and ideas are welcome.
Thank you.
I dono, and I shrug ?Who is John Galt?
Otherwise very good conversation.
Also look up the big natural gas generators. If you are lucky enough to be near natural gas lines (they don't even need to be super big), you can just feed them natural gas and they crank out power. Lots of big units used in the oilfield to power electronic submersible pumps (ESPs). Company I work for has ~150 ESPs in the Permian basin sucking down 400-500 kW each. Many ran off generators. Some natural gas (burning natural gas that would otherwise be flared off), some diesel. They're designed for high reliability.
Let's run through the math for a Cat CG127-12 TA engine (used for electric generation and gas compression).
400 kW at 480V is 100% capacity so you'd need 2-3.
Fuel consumption at full load = 4906 SCF per hour (this shows at 905 BTU/cf, which is a bit below what usually comes out of pipelines). Going to use 1000 BTU/cf, which is a bit more realistic and easy for math purposes, so that's 4906/(1000/905) = 4439 SCF per hour x 24 = 106558 SCF per day. That's 107 Mcf (oil/gas uses M for thousand) per day. Current henry hub spot price is $3.07 per MMBTU. Since we used 1000 BTU per CF, that convienently results in the same price per MMBTU as MCF. So you're using 107 MMBTU * 3.07 $/BTU = $328.49 per day of gas. You're also generating 400 kW x 24 hours = 9600 kWh. That's a cost of $0.034 per kWh (3.4 cents per kWh).
You won't get spot pricing, but you'll get close to it at 100-300 mcf/day. Amortize the generator cost over X years and you're good to go. These generators are also commonly available for rental/lease if you want to test things out.
Also the efficiency goes up slightly as you back off from full load. If you run 3 of these at 83% each (3x333 kW = 1 MW), you'd be near peak efficiency.
Here's a list of CAT engines in this product line - https://www.cat.com/en_US/products/new/power-systems/oil-and-gas/land-production-generator-sets.html
Edit: there is a lot of interest in this area to burn natural gas to generate electricity in the oilfield to power bitcoin miners. The gas would otherwise be flared. Up to you to decide if that's a valuable venture or not (hint: the mined bitcoin has 2-3x the value of the generated electricity).
I've got hundreds of unused acres, real estate is not an issue. My problem is that the power company does not "buy" back, but they'll take it for free.How Much Investment Do You Need For A Solar Farm? | Coldwell Solar
When it comes to alternative investment options to pick from outside of bonds and stock, the solar farm is one of the popular choices. We say this because it also...coldwellsolar.com
From looking at this page it appears a 1MW plant would produce 1440MWh a year average, and profit around 43K, so the 4hour average daily production would likely cut your usage by 1/3 to 1/2 depending on operation times.
If you contacted tesla you might get a MWH of battery modules for another million... you might get enough from solar to eliminate your energy draw from the grid entirely...
Heck...
Add another MW of production and get PAID by the power company to produce power that will stabilize THEIR grid...
Assuming of course ya have 16 or so acres available...
It's a quote from the book atlas shruggedI dono, and I shrug ?
That's crazy, when their production is weak and unstable that they wouldn't buy from. You.I've got hundreds of unused acres, real estate is not an issue. My problem is that the power company does not "buy" back, but they'll take it for free.
A friend of mine recommended a hybrid system as well, were we produce about 50% of our own power, through solar and batteries, and use the grid for the balance of power needed. We'll see, stil researching solutions.
I need to look into Tesla MW batteries. They seemed expensive on the consumer side, although they may have better deals for commercial users.
They can purchase more energy, but they're cheap.That's crazy, when their production is weak and unstable that they wouldn't buy from. You.
Yep that's a bit far. For $4MM there are plenty of other, better options, including giant batteries and solar/wind to match. Not to mention the price of natural gas, even though there are supply/demand factors to keep the price relatively low, can be highly variable.Thanks for this.
I was able to speak with our local NG supplier. Nearest main is about 11 miles from my location.
Rep. quoted me an approx. $4MM design and build out, which was a bit pricey. I could justify a quarter of that costs.
Propane can be delivered to my location, but it's about 4x the cost, I believe, for the same energy density.
