Holdontight
Is anyone aware of a DC to DC converter that can take a max input of 65V and output no more than 60V? I'm using a Bluetti AC180 and trying to input up to 60V at 8A into it.
Thank you
Thank you
You will lose everything you gain with a step down module.
Thank youYou may use a step-down module. In Aliexpress there many.
Step-down module is a very easy way to supply a current at a voltage no higher than the supplied.
The nominal power of the module will limit the current or you may purchase one with current regulation for some extra dollars.
https://es.aliexpress.com/item/1005...25c56044d03ab195e3615455980&afSmartRedirect=y
Thank youThen what about a DC-DC buck boost converter with current limiter?
I have one and it can transform a DC voltage into a lower or higher voltage while providing a current from 0 to 5A with 0,001 accuracy.
Problem is that mine is only for 80W, but there should be for 500W.
Example:
https://es.aliexpress.com/i/1005005070334058.html
In my case I got 73W out of the 80W advertised.With a buck converter it will no longer be MPPT. These all in ones are a bit of a scam. They always spec an input voltage and current that can't be obtained. They rely on you not being able to meet it. If you could find a panel that matched the specs, the unit would burn up.
How can you be so confident that your results are scalable?In my case I got 73W out of the 80W advertised.
If I used the maximum input voltage the unit can take and output the maximum voltage the unit can offer, I'd get much closer to those 80W.
So indeed, If you want 500W, get a buck for 600-800W. Then the overheating will be more balanced and you'll comfortably reach your 500W target.
Tell us your situation and the problem you're trying to solve, there's possibly a better solution here.Is anyone aware of a DC to DC converter that can take a max input of 65V and output no more than 60V? I'm using a Bluetti AC180 and trying to input up to 60V at 8A into it.
Thank you
Thanks. I'm using Renogy 100w panels with an open circuit of just over 21V. Unfortunately this is just over the 60V input limit of the Bluetti AC180. I was hoping the 60ft of cable would have enough of a voltage drop to work, but that's not the case.What solar panels are you trying to use? Is it possible to connect them in parallel for lower voltage? With DC-DC converter you will lose MPPT function of Bluetti.
