8milimeter
- May 25, 2020
- 54
Which parameters would you like to monitor ?View attachment 15996
I would like to monitor the system, any suggestions on shunts and displays would be appreciated.
Yip , close to the alternator.should have a fuse between the alternator and the dc2dc charger.
Yip , at the main + battery terminal.If it was me I would consider a master disconnect switch.
A couple questions I have are 1) the advantage of the DC to DC vs using a simple isolator?
2) Does the shunt on the + vs shunt on the - make a difference? I'm sure that these questions have been answered elsewhere, so I'll go search...
A simple isolator is not appropriate for lifepo4 house batteries.
Lifepo4 batteries have such a low internal resistance that they can draw enough current to hurt themselves.
Shunts typically go an the negative leg.
I'll probably lean towards one of the MPPT solar charge controllers with the DC-DC built in.
Thats not a common combination.
Do you perhaps mean an all in one.
inverter/charger/solar charge controller?
I should probably start my own thread so as not to distract from the design/diagram that the OP is fine tuning.
The two controllers I've come across so far that combine MPPT solar with a DC-DC charger in one unit are the Renogy DCC50S and the KISAE DMT1250.
Given that my current converter is an older PD model and the inverter I have is a modified sine wave, rather than pure sine wave, perhaps I should explore whether or not an all-in-one makes sense.
I've been tending towards using the components that I have and keeping investment minimal since the RV I'm fitting this to is likely to be replaced with a newer unit in the next few years. My current converter does have the Charge wizard button to force it to Boost Mode (14.4V), so I've been treating any converter upgrade as optional, and I figure that the 1500W modified sine wave inverter that I bought years ago, but never installed, is already paid for, so I may as well use it.![]()
The Kisae has a max solar input voltage of 50V which is more practical than the Renogy's 25V max limit.If you go with the KISAE DMT1250 please give us your review.
