Cheap 4-life
My body is 2.63 trillion volts, .07v per cell
not sure if this is the correct section for this. It wasn’t my mistake. but wow what a blast.. Probably a battery/phone in the dryer
I don’t think a lighter could blow out the front of the store.What kind of camera was that? It was framed like a cell phone camera, which makes me suspicious that is was staged. The motion tracking made some sense, but why would the default pointing location be that dryer, and why would a surveillance camera have that aspect ratio?
If anything, though, I would maybe suspect a lighter in a pocket. I don't think a battery in a cell phone would be contained enough to cause that kind of explosion, but butane igniting in a lighter might.
That said, I am not an expert in explosions, but I do have a dryer an some pretty old and large NMC batteries!
shorts are always like that, it is enforced by YT.
The camera was focusing on moving parts - as that is the most common behaviour.
From what I seen of lithium cells being punctured there is an explosion and I’d assume more so in a contained space. The containment was the door sealed shut. Not 100% sealed but contained more so then being out in the open. Then it blew open from pressure then the air then the flames.wouldn't think a cell phone battery could either. NMC batteries burn fast and hot, but it requires containment to cause an explosion.
I would think this would be more of an overheating than a puncture.From what I seen of lithium cells being punctured there is an explosion and I’d assume more so in a contained space. The containment was the door sealed shut. Not 100% sealed but contained more so then being out in the open. Then it blew open from pressure then the air then the flames.
There are bigger lighters than bics. The crack torches sold all over town can hold as much butane as 5 bic lighters.I don’t think a lighter could blow out the front of the store.
