Still need me big coat though.....?️![]()
After almost 2 months of grey , grey. grey cloud...yesYeah, but your panels will be nice and efficient![]()
Oy! You've been keeping me awake last night, pondering how you achieved that amount.Partly sunny in the SE today. Generated 6.2kWh from a 3kW array Peaked at 1.1kW
I have to apologise. My peak wasn't 1.1kW, it was 1.6kW. I don't usual use the Solis Cloud app or website, I go by my own monitoring utility which pulls the figures direct from the inverter. I made some code changes and restarted the program which reset the daily peak figure (about the only thing the inverter doesn't store and doesn't get logged). The rest of the figures were accurate.Oy! You've been keeping me awake last night, pondering how you achieved that amount.?
I'm just a bit further north than you in East Anglia and only achieved 4kWh from my 6kWp array on similar, mostly sunny day.
I got a peak of 1.8kW (which makes sense compared to your 1.1kW with half the panels, but mine are E-W facing, so would expect the peak to be a bit less).
BUT... sunrise is 8am and sunset at 4pm, so for you to get 6.2kWh with a measured peak of just 1.1kW would suggest you had that full power for 5.5 hours, when there's only 8 hours of sunlight in the day and a maximum sun elevation of 17 degrees.
Doesn't seem to add up to me unless:- a) you've installed a fancy new dual-axis tracker or b) the Solis cloud app is playing up?
Would be good to compare our outputs for today.
No... it's just because my panels are at right angles to yours! So what did you generate yesterday?It must be local weather.
