Growatt settings
w24
at home
Hello everyone
I'm new here and also my two Growatt SPF-6000t-DVM-G2 are brand new...
An that's the problem: I can't find anywhere how to change the settings at
https://server.growatt.com/ --> My Photovoltaic Devices --> Setting
and what the individual points mean...
Where can I find a description or instructions?
Thank you for your help!
I also have two Growatt, SPF 6000T and SPF 12000T I changed all settings locally when I powered up both units. I only use the Growatt server to monitor, The manual has a list of parameters and default settings, I believe a password is needed to change the setting via the server, and is kinda confusing because different verbiage is used for some parameters, I have used the password to test and found "growatt20240116" with current date used has worked "growattyyyymmdd"
Hi bruceonlan
Thanks for your answer!
Can you also please tell me what all the settings and options mean or where I can find more information about each setting?
For example:
"Ac Input Model" hast the options "APL", "UPS" and "GEN"
What does this mean?
Also , in "Advanced settings" on the server it shows the following settings:
What can be registered here and how?
I do not use the server for settings as the language is different for many parameters, I set all parameters at the local device and step through the user manual that came with each device, do you have the user manuals?
available here: https://us.growatt.com/products/spf-4000-12000t-dvm-us-us-mpv
I believe if you know the values you can push values into individual registers, not something I would try. The manual has good info on all the needed parameters to run the devices for my applications
