I am no longer at the conference sadlyHey @Will Prowse can you take a picture behind the panel? I wonder how they run the coolant through the panel. It it just picking up heat from the edges or is there coolant channels that run behind solar cells?
Get your butt back there. We need more information. lolI am no longer at the conference sadly
Well.... Er..... No....BUT WAS IT 76% EFFICIENT!!!???![]()
And a butt-load of weight on your roof....I seriously contemplated a diy setup like this.
Free hot water
Active cooling of the panels
Snow melting for winter
Not really.And a butt-load of weight on your roof....
0.09 lbs per foot.
200 ft would be 18 lbs.
My weight reference was for my diy approach.I expect the added panel structure and heat exchanger is notably heavier than the water.
Similar product, though I don't see the thermal rating:
aHtech 72SK Hybrid Photovoltaic and Thermal PVT Solar Panel (in Stock)
Hybrid Photovoltaic and Thermal PVT Solar Panel, generates both electiricity and hot water. Ships Canada/US wide, to order please call +1 (888) 686 7652.hydrosolar.ca
2sq-m meters.
110 lb
hold 1/2 gal of water or about 4 lb
So about 2.5X a typical 2sq-m panel.
Assuming a 15 x 40 foot roof face and a wet snow, your roof already supports over 2000 pounds for every inch of snow.110LBS each panel.......plus fluid....... fittings, etc.....
