Victron MPPT over panelling
Urge38
London Uk
By how much can you over panel a Victron 100/20
the data sheet just says the MPPT will deal with it !!!
a) If more PV power is connected, the controller will limit input power.1b) The PV voltage must exceed Vbat + 5 V for the controller to start. Thereafter the minimum PV voltage is Vbat + 1 V2) A PV array with a higher short circuit current may damage the controller
On my Tri Star, it states 130% of Nominal Max Ouput Power
You have to be careful with Victron SCC's.
They aren't like other MPPT's.
Part of their sweep includes shorting the circuit.
They are very limited with overpaneling.
You can over panel Victron solar charge controllers, it will limit the charging current to the max designed amps or you can lower the charging amps in the settings. My two 100/30 connected to 1200W solar panels each, the 100/50 connected to 1620W solar panels. No problem at all. Running like that nearly 3 years.
I have 600w going into a Victron 100/30 (max output of 420watts) works fine except the mppt gets very warm (almost hot).
HUH? You know I hate to argue with you, but I think we disagree here...
They publish two rules, both values are published in the MPPT datasheets:
Array must never exceed Voc (100V in this case) even in cold conditions.
Array short circuit current, Isc, should not exceed PV input current limit.
I post this so damn much, I've updated my signature.
@Urge38, please see link #8 in my sig.
Limits to Oversizing a PV array
How to determine by how much you can oversize a PV array? This can be done with help from the spreadsheet tool. Here though is the manual explanation of how it is done.
There are two limits, when determining the maximum array size that can be connected to an MPPT:
  1. The Maximum PV open circuit voltage (Voc at STC)
  2. The Maximum PV short circuit current (Isc at STC)
Both values are specified in the datasheets of all our MPPT Solar Charge Controllers. Those two ratings of the PV array must not exceed these MPPT limits.
It doesnt show up on VRM. If you connect to your SCC via bluetooth you will see it. Every 10 minutes or so it goes to 0 output for 2 seconds.
You can also connect to the MPPT via VRM with VC:
You CAN'T access the device logged TRENDS tab data. This is stored in the BT module, and you must connect via BT to see it. HOWEVER, you can open the TRENDS tab and start capturing live data.
Set your VRM interval to 1m, and you'll often pick up the MPPT sweeps.
Good thread!
I had thought it was like sunshine eggo stated. Glad to see confirmation on it.
So for example I could run 2200w of panels on my 150/45 in 24v mode and only capture 1300w as long as I didn’t exceed the max voltage and current limits.
That has not been my experience. Serious over paneling (300%) doesn’t seem to bother the ones I’ve used.
I'm not an expert on Victron equipment, or anything even close. My information on Victron is strictly from this forum.
You know that I am at your mercy when it comes to Victron knowledge.
But, isn't this what I said?
Maybe I was misunderstood?
Your first comment of very “limited with over paneling” would imply max PV is determined by the charge current limit. IE don’t exceed 720w 30a at 24v, where that isn’t the case.
Where it might make more sense stick to victrons published limits and you can over panel pretty substantially.
I guess that I was misunderstood.
Overpaneling (to most) means exceeding amperage limits.
But, I suppose the word could also be used for exceeding wattage rating. While remaining below VOC and ISC of controller.
I would not consider that Overpaneling. Because you are within the two limits.
Victron are fine with overpanelling relative to the output of the SCC. In fact they even recommend it.
Have a play with their MPPT calculator and be sure to click on the 'Allow oversizing above 130%' tab.
This is what they have to say about oversizing...
"You can now for example add the same type of modules in parallel later without the need to change the MPPT charge controller. This reduces costs to a minimum, whilst still increasing the yield!"...
..."The big advantage in doing this is that you will now produce the maximum controller output at a lower irradiation. As module prices decrease, this is an effective option"
I have a couple of strings overpanelled by 200% to Victron SCCs and it works well. Much more consistent yield from day to day under varied weather conditions.
Here's an example I'm running on a 12v system. 1200 watts of PV going to a Victron 100/50. 6 200 watt panels in a 3S2P configuration.
The 100/50 has a max output of 700 watts to a 12v system. But by giving it 1200 watts of panels to draw from, it can reach that 700 watts output for longer through the day and also on those less than ideal days. More consistent output throughout the day and also from day to day.
I completely understand the reason for overpaneling.
I have done it in extreme fashion.
What amperage were your panels?
What amperage limit for the SCC?
The 100/50 has a max PV short circuit current of 60A.
Really?
That's awful high.
There shouldn't be any issues with that, at all.
The panel's Isc is 11.89, so 23.78 amps short circuit for the string.
How would this be considered overpaneling?
Wait, it's a 12v system using a SCC capable of 48v.
So, it would be very hard to overpanel on a 12v system.
Because it's not capable of even using, up to the limited amperage.
Really?
That's awful high.
Here's the specifications for the 100/50...
It can only do 12 or 24 volt systems.
Overpanelling is when there is more watts of PV than what the maximum output of the SCC is capable of outputting to its particular system. It means there will be clipping as the SCC becomes maxed out rather than having a SCC that can output as much PV wattage that is attached to it.
Victron is a different animal.
With other equipment, the wattage output closely matches the voltage and amperage limits.
Overpaneling usually requires exceeding the input amperage limit.
I suppose it is different because of the multiple battery voltage capabilities.
This is usually why I defer the Victron questions to @sunshine_eggo lol
Epever has a 1.5 times maximum PV input wattage relative to the SCC's output wattage.
Overpanelling is commonly thought of as having more PV wattage than the charge controller can output.
ie...
"1800W of panels feeding a 1200W SCC is 50% over paneling, about the maximum that makes sense (unless you have a very particular situation) and close to the maximum that Epever specifies.
I have the 200V model of their SCC but the manual specifies a maximum of 1875W PV power for the 1250W-rated 5420AN (as well as the 150V 5415AN).
1875 / 1250 = 150% (exactly)."
Again, multiple battery voltages.
I still think that my original statement stands true.
You have to be careful with overpaneling Victron SCC's. Too many amps will damage them.
Unless I misunderstood previous conversations on how they operate.
