Hi All,
I have a Growatt SPF5000es with a Dyness A48100.
I noticed that after an extended power outage, the battery reaches 20% and the system shuts down as it should.
However, when the grid power returned, the inverter did not start up itself. I had to manually switch off the inverter (I/O switch) and then it recognized that the grid power has returned.
My problem is that my entire home is routed through the inverter and if this happens while I'm away on holiday, my fridge contents will go off.
Does anyone know why it does this?
