BrunoAlves
I installed 2 parallel growatt inverters with a Seplos BMS and a big pack of 280Ah EVE Lifepo4 cells. All is working fine and the inverters were really easy to set up (apart from ShinePhone, what an idiot setup...)
There is however a point where I think the inverter is missing a basic functionality...
I use the grid as the backup source (SBU). We can configure the maximum charging current, but that's DC current. Nowhere we can tell the inverter what's the maximum grid current (AC) available.
So, in a situation where the batteries are charging after reaching the minimum and the grid is powering also the house, if the consumption gets too high I would expect that the battery charging is reduced or even interrupted so that the grid isn't overloaded and eventually shuts down. But it does, I had that.. Now with winter coming, less sun, I guess that it might become a recurring problem.
Did anyone came across this problem, any way to fix that?
