Offgrid Aussi
Hello Guys,
My off-grid setup consists of only one 3kW solar array, a Growatt hybrid inverter (SPF 5000ES) and a 13kW battery.
To use the full potential of the SPF5000, I want to add a second solar array, but that inverter can only handle one.
A Growatt 5500MTL-S that can handle two arrays rests in the shed and could be utilised, but that is a grid-tie inverter and will only work with a stable 220V connection. So I would have to connect it to the AC output port of the SPF5000.
I heard that the Victron MultiPlus can handle AC input on its output port, so you can add grid-tie inverters to your off-grid system and push AC currents "backwards" through the Multiplus to charge the batteries, but can you do that with the Growatt SPF 5000ES as well? I tried to get a response from them, but had no luck so far.
Has anyone here been there and done that?
I rather consult with you guys than take my chances and watch everything go up in smoke.
So any thoughts are greatly appreciated.
Kind Regards
Offgrid Aussie
Kind Regards
Offgrid Aussie
