I’ve built a first 90Ah 8S battery and am planning on building a 280Ah 8S battery soon.
The 90Ah is my first battery build and I’m trying to characterize the battery to figure out if it is behaving normally or not.
I’m charging with a 10A 28.6V LiFePO4 Charger that gets the battery up to 28.75V before shutting down (3.6V/cell avg).
After charging, I’m not applying any load and am disconnecting the BMS balance wires (to eliminate the possibility of any balance currents in case that is impacting the results).
I’m characterizing the post-charge settling I’m seeing and in the 3 hours immediately after charging, the battery is dropping to 28.15V (avg of 3.52V; avg loss of 75mV).
In the following 12 hours, the battery has dropped to 27.82V (avg of 3.48V; avg loss of 80mV).
The cells are still higher than the 3.35 - 3.40V others have reported as the typical ‘settled’ voltage post-charge, so perhaps my cells haven’t reached their final ‘settled’ voltage yet, but my current thoughts are to let the battery settle for another ~48 hours to see if the cells stabilize once they reach 3.35V or keep settling beyond that.
If anyone else has characterized what happens in the hours and days after their cells are charged to 100%, I’s appreciate any insight.
Once I’ve confirmed that my cells are behaving normally as far as retention, I’ll reconnect the BMS sense wires to see if that dramatically changes the results or not.
