Once you hit the current which the resistor will bypass (V=I*R) across that cell, the cell will stop charging. The current passing through the resistor will continue to charge the other cells. Eventually you will have all but one cell bypassed, and that cell will be charging at the resistor bypass current. Takes a little fiddling, but as long as your BMS is working, there isn't any risk of cell damage.
I’m intrigued but not yet understanding.
I’ve got an 8S battery, a 10A Charger, small parallel Port sense wires that can manage 1-2A but no more, a small 1.5A 5.2V Charger, and a 2.5ohm 50W power resistor.
Are you talking about a resistor between the charger and 8S battery leads or if not where?
