tomy2
escape artist
I would like to add a mini split system to my house, it is 240V and my solar fed subpanel is 120V.. Can I safely use two legs of the subpanel to feed 240V to the compressor unit? The subpanel is fed by a 5000w EG4 inverter with 30A breaker. I need to decide between two mini splits, both are 1 phase 208/230 V. One is a 1800BTU which has a Minimum circuit ampacity of 16A and a rated Current of 7.3A, max fuse 25A, and draws 1700 watts max.. The other is a more efficient but smaller 1200 BTU with a Minimum Circuit ampacity of 15A and a rated current of 4.1A, max fuse15A and draws 907 Watts. So my question is, will a two legged breaker in a 120A subpanel work for either or both of these units, or do I need to add some kindof transformer?
