aunsafe2015
I'm thinking about a very simple setup. A 120v Reliance Controls manual transfer switch that is powered by a battery system + inverter when in "GEN" mode. 10-15 kW of battery capacity, probably EG4.
All I need the inverter to do is keep the batteries charged and to output (up to ~3000W) to the Reliance Controls MST when power goes out and I flip the MST from "LINE" to "GEN". Nothing complicated. No scheduling, no solar, no generator. Any suggestions for the simplest, most reliable inverter for use in a simple setup like this one? Thanks.
Edit: Edit to add that simplicity and reliability are primary goals. If an inverter capable of outputting 240v is better than any of the 120v options then that a 240v inverter fine with me.
