Hi,
I'm a newbie and I want to direct connect a 120w, 5a solar panel to 5v. 3a usb to charge the devices during daytime.
First attemp was with a 12-24v controller but it get "fried" in the end (don't know why, because I supposed that the 2 usb outputs are also regulators, but seems not):
...and after get "fried" shows like this (the files in the attachement)
The second attempt was to buy these regulators: Youmile 10 piezas DC-DC Buck Converter 6-24V 12V/24V a 5V 3A Módulo de cargador USB Regulador de voltaje reductor Módulo de fuente de alimentación con cable rojo y negro de 24 AWG https://amzn.eu/d/hBSmuCM in order to split the cables from the panel and to connect, say, 4 of them (5vx3ax4=60w, the panel has max 120w), but when I tested one directly on the panel cables it get "fried"! Don't know why because the panel is 12v, 120w, so max 10A! The strange thing is that it works with a usb car charger (lighter plug) in direct connect but why doesn't also work with the regulators which I bought?!? What kind of regulators (better with usb) would you recommend to make a setup with 5-6 usb outputs direct connected to the panel? Guess it is possible since a car charger can do it!
Thanx
Thanx
