You know, if you could just be sure that Himassi uses quaility, grade A cells in their batteries then I cant imagine what else would hold you back from grabbing one. If we could get someone out there to tear a Himassi down on video, you'd be all set. Since you havent bought a battery yet, youre also in a position to build your own out of individual lithium cells which, knowing what I know now, is what I would do if I were you. From what little Ive looked into the matter, building your own storage out of individual cells these days costs about the same as just buying an equivalent, pre-made Lifepo4 battery, but would pay off down the road because you could balance your system much more precisely and replace cells as/if they go bad instead of an entire battery.I am also looking for some to say it is okay to buy Himassi! I have 2 HQST 100-watt panels on my van with 2 lifeline 6v batteries in series.
I understand what you mean about purist and mixing in the past. However it does seem like Lifepo's might be more vulnerable to issues since they have a BMS. Just seems like there is a lot more going on in a Lifepo compared to AGMs.
Unfortunately, having already bought and installed 4 Wieze batteries, Im in a totally different boat.
