Visionquest
I want to design an insulated box with heaters for a 12v Lifepo4 battery build. I'd like to apply just enough power inside the box to keep the cells around 40 degrees without on/off cycling of the heat. E.g. - the colder it gets below 40 degrees, the more power will get applied to the heating pads. I'd like it to work down to zero F where it would apply full power. So I'm looking for help with any of the following areas...either example builds or suggested products.
1) How to size the heating pads power. If I use R10 insulation around the outside of a 14" x 8" x 9" box with four EVE280aH cells and a BMS inside, how many watts of heating power will be needed to maintain the cells at 40 F in an ambient temp of 0 F? (assume no self-warming in the cells)
2) What to use to do a variable voltage control of the heaters? At 0 F they should be at full "12v" voltage. At 40 F ambient they should be down to zero voltage. I'd like the heater control to apply as much voltage as needed to maintain cells at 40 F throughout the range of ambient temps from 0F to 40F. Does this product already exist somewhere or do I need to design it from scratch? (My background is electronics design.)
3) what is the best sensors to use and best place put them in the cell stack? in between the cells? top? sides? Terminals? What will be the most representative of internal temperature?
Thanks for any help and suggestions!
