dubaron
- Jun 13, 2020
- 10
In August of 2020 i installed a DIY 150aH LiFePo4 battery with a JBD 100A BMS into my VW camper. The battery is charged with a Renogy DCC50S using the alternator, I have not connected a solar panel to the system yet.
I recently installed the Overkill BMS app on my iPhone, I was using the XiaoxiangBMS app. I loaded up the 4S template config in the Overkill app and since then I've been having strange issues. I went back to the XiaoxiangBMS app and wrote a previously saved config to the BMS and it started to behave. I thought things were good, they aren't. The SW switch enable is disabled, the Load function is disabled as well, both of which caused funkiness after loading the Overkill template.
This past weekend during a 3 hour drive to a campout, I noticed that the discharge current was not showing and the charging current was under 10amps. Then the charging current stopped and the discharging current was displayed. It would flip back and forth, it never showed both charging current and discharging current simultaneously. The load was the stereo and the fridge, about 5 amps.
I have disconnected the BMS power for a few minutes and then applied the power, no change.
I downloaded the Overkill BMS app because the BMS was misreporting the SoC - it would drop to 15% charged but showed 13.3 volts. Changing the "Total Cycle Capacity" value from 120000 to 135000 and then back to 120000 would cause the BMS to report the percentage being far closer to reality, 70% or there about.
Is my BMS dying? Is there a way to "hard reset" it?
-Steve
-Steve
