tmprof
I am currently installing 12 SEG 460W bi-facials . I was wondering if this would be ok to run all off the #1MPPT on the 18k? I live in Houston so the temp doesn't get much below freezing.
Panel info:
VOC - 41.52
ISC(A) - 13.96
Vmp(V) - 34.48
Imp(A) - 13.34
Using online calculators:
All Panels wired in Series
Max Power - 5519.56W
Voltage - 413.76
Amps - 13.34
All Panels wired in Parallel
Max Power - 5519.56
Voltage - 34.48V
Amps - 160.08
Using the 6s2p
Max power - 5519.56
Voltage - 206.88V
Amps - 26.68
It seems the 6s2p will have too much amperage for the single MPPT 1. I assume it's safe to just run them all in a series?
Thanks for your help.
-Troy
Panel info:
VOC - 41.52
ISC(A) - 13.96
Vmp(V) - 34.48
Imp(A) - 13.34
Voltage - 413.76
Amps - 13.34
Max Power - 5519.56
Voltage - 34.48V
Amps - 160.08
Using the 6s2p
Max power - 5519.56
Voltage - 206.88V
Amps - 26.68
-Troy
