Model is gbli 2701Agree with the above we may be able to determine the cells if you can find the exact model of growatt battery
I read the larger uses Boston Power Swing 5300 cells,Catch 22 then, the cells are not the current normal LFP cell, the specs online are not detailed enough. So keep it topped up until you can do more work on it. It seems to be an early Lithium battery using some specific cells no longer made, can't find any more info.
. The charge of the packs is aprox 3.7 and fairly balanced +-0.02v and total charge is aprox 52.6v and has been stable for monthsDischarge cutoff 2.75V/cell, what are the cell voltages and how many cells are there?
So you have 14.2 cells in series?. The charge of the packs is aprox 3.7 and fairly balanced +-0.02v and total charge is aprox 52.6v and has been stable for months
I just reconnected bms after giving a clean and nothing on the output.
Could you have made an incorrect assumption before co.mng to that conclusion?So you have 14.2 cells
You said:Could you have made an incorrect assumption before co.mng to that conclusion?
Just a gentle hint using humor to nudge you in the direction of giving us all the available information. If you were to tell us how many cells there were, that would be useful, but for some reason it seems to be a deep dark secret. Should we sign an NDA? <--- more humorIs there something helpful I should be getting from that comment?
so I just did the math.
Just a gentle hint using humor to nudge you in the direction of giving us all the available information. If you were to tell us how many cells there were, that would be useful, but for some reason it seems to be a deep dark secret. Should we sign an NDA? <--- more humour
