Johno1066
Tried fitting power meters into my incoming pv negative's by means of shunt resistors. The main problem is that most of the DC power meters operating voltage does not exceed 100 volts. and my pv voltage is around 190 volts. I found one that could read up to 200 volts and you could use a separate power supply to operate the device. Bought one and hooked it up to one of the EG4's using a 12 volt DC small charger similar to these little telephone chargers. The little device worked quite well could now see the pv voltage, pv current, watt input and recorded watt hours over time. What i wanted was a means to record my watthour input over a normal day, but as I had 2 EG4's in parallel I ordered another of those devices. Now with only one power supply I set up 2 sets of pushin connectors so as to be able to power both devices from a single source. Wired up the second device and before cutting the other pv negative connected up the second device to make sure it worked. As it was working I disconnected its power shut down the pv input and connected the negative through the shunt and turned the pv back on and all was well until I pushed in the 12 volt power into the second device, there was an immediate pop and all shut down right into the batteries as well. The only thing i can think of is that the 12 volt power supply made common the 2 negatives of the 2 pv streams and resulting in 2 dead EG4's I have ordered 2 replacements and have spoken to Signiture Solar about possibly repairing the damaged ones but that does not look too good. Anyone else do repairs on these things as I suspect that the charge controllers are probably damaged.
