Hello,
I have 2 Growatt 5000ES and 2 lithium batteries Felicity 8.7 Kwh each.
Both batteries are connected in parallel and act as one big battery
The inverters are connected in parallel and both are connected to the big battery.
All is working great! The problem is that each inverter is reading the battery slightly differently.
If inverter 1 is reading 90% , I notice inverter 2 reads 89% sometimes and so.
However I noticed when there is no load on both inverters, one would be discharging the battery at 100W and the other charging the battery at 48W.
Is this normal? And if not does this hurt the battery? Im worried the inverters are charging the battery from itself
I attached the images from the inverters
Thank you
Thank you
