apctjb
- Jun 16, 2020
- 480
Recently installed 2 SPF-3000TL-LVM-ES 48. Tested after installation and inverter and MPPT charging all worked fine. (No grid hookup so did not test utility charging) They worked for about a week in MPPT charging mode (inverter side was not turned on as did not have loads attached). After a week I went to connect loads and powered on one of the two inverters (the 2 inverters were configured to operate in parallel (setting 23=PAL), there was buzzing noise, then error warning, then three load pops (no smoke) and one of the inverters when dead. No load was connected to either inverter at the time. No display, no response when powering on.
Looking at the data log there was an over current error prior to the inverter failure.
Anyone else experience a similar situation and any suggestions on how to troubleshoot/repair?
