My experience with the Growatt SPF 3000TL LVM-ES is that it draws about 40-50 watts from the batteries even when it is in bypass mode. This adds up to about 1kwh a day drain. So what happens when there is lack of solar and the batteries get down to the low voltage cutoff? Does it shut completely down and even disable the bypass? My experience so far is that if the unit is shut off it will not even do the bypass. I can't have my power go out because the stupid inverter drained the batteries so low that it kills the bypass mode.
