Yes. I assume you mean 200ah and 100ah LFP respectively placed in parallel. So long as each connects to a bus bar with the same length cable the load should divide proportionately. You could also wire them with each of the 2-100ah hooked together (short cable pos to pos and neg to neg) and than diagonal pos and neg to your bus bar. This would reduce your needed bus bar connections by 2 per set.
