24v vs 48v
ab1
Lebanon
Hi,
I am planning to buy 16 cells lifepo4 , I already have 24v inverter. My question is it ok to build 2 x 8s for 24v system with 2 bms on each pack, or is it better to build one 48v 16s battery bank with one bms, and buy a new 48v inverter?
If you already have the 24v inverter, it is fine to use 24v 8S bms on them.
What are your loads? Would a 48v inverter be a benefit?
Reactions: ab1
Build the 2-24vDC now (run in parallel) and rebuild it into a 48v one if needed in the future. You will have access to the cells easier if you allow for it during build.
Reactions: ab1
