Ej Bms Lithium Battery Case With Bms 4s 200a 2a Active Balance For 280ah 302ah - Buy Lithium Battery Case 12v 280ah,4s Bms Lifepo4,Active Balancer 4s Product on Alibaba.com
Found a battery box that will fit 4 of the 280ah cells with room for the BMS as well. 335mmL 180mm wide 215mm high. Uses a M8 button post which is common on AGM batteries. Working on getting a few in for my batteries. Will let you all know how it works out. Greg
