douglasheld
Hi all, I've completed my first project. Location is London England, on my detached garage roof.
So my goal was to have some fun, create something, get to understand the basic of solar energy in my region, and to have the ability to run power tools, a (1700W rated) shop vac, and add lighting to my garage. The garage isn't attached to my house, and I didn't want the hassle of a utility-provided electrical supply there. Instead, I simply asked the freeholder for permission to try this out on the building roof. Meanwhile, the interior space of the garage is mine to work with.
Result
Well, it was great that I had my setup to power my drill to put the electrical panel together.
Notice I used the pieces of the stainless steel shel upside-down, to make a tray with a lip to hold the battery. I think the wood screws in the 18mm OSB3 are going to be strong enough to hold this heavy battery.
I've also vacuumed out my car several times - something that's been seriously difficult for me to do before my inverter setup. I'm looking forward to doing more work in the garage now - using my table saw etc. to build out further.
If I need to I might add another panel with a second identical battery in parallel.
Finally, when we buy our next house in the next few years, I am looking forward to installing a home energy storage system.
Photos
- single Nicesolar 120W monocrystalline panel with MC4 connector cables and a 20W PWM charge controller (starter kit sold on Amazon, the listing is now gone)
- I built an approximately 60˚ frame out of 21mm slotted channel steel and A4 stainless machine screws. This sits on the roof on nylon feet, with some adhesive 3M VHB pads to hold it in place without damaging the roof material.
- I don't have a photo of this frame - but it is simple
- the roof surface is "box section composite roofing sheets 40mm sandwich insulated" - probably polyester or painted steel.
- 130 Ah 12V deep cycle battery, sold on EBay (https://www.ebay.co.uk/itm/274087465400)
- Some simple electro-plated brass battery terminal connectors (https://www.amazon.co.uk/gp/product/B091J24DXX)
- 12V 250A circuit breaker (https://www.ebay.co.uk/itm/124618845893?var=425550653287)
- 2 AWG pre-crimped cable (https://www.amazon.co.uk/gp/product/B0B5G9FGKY)
- 12V -> 240VAC 2000W pure sine wave inverter (sold on Amazon, the exact product is now gone https://www.amazon.co.uk/gp/product/B0B11VT378 )
- I even bought an 18mm OSB3 panel off of EBay... (https://www.ebay.co.uk/itm/224604576826?var=523413055972)
- It's nice to have a panel pre-cut and delivered!
- a simple food-service stainless steel tray (https://www.amazon.co.uk/gp/product/B0BBWM71KB)
- Some really simple USB LED lighting strips (https://www.amazon.co.uk/gp/product/B0B83WGCVQ)
Result
Photos
