Good day to all members.
I want to power an Rpi4 of the grid that will run with a 2 series 18650 through a power management board.
My setup is a 10w polycrystaline solar panel 18v (open circuit 24v) that connects to a CN3722 mppt board(not sure if its 2s or 3s) and then to a 2s HX-2S-JH20 BMS. After that to 2 series 18650 Panasonic batteries. Now as i had connected the setup i can see the charge of 8.2-8.6 v to the batteries. Don't know if 8.6 is safe for the batteries but at the same time the BMS start to smoke. Input to the BMS is the same after the mppt board 8.2-8.6v while the panel output is on the 22-24v range. Any ideas on how to approach a similar setup?
I will post photos later
