This project is 54 panels 400watt bi facial on a 21x60 roof over 100ft from house 6 gauge wire 100%.
the peak power kw use was almost 30kw. So I want to make sure that power is available if needed.
the home has 2x200amp meters and breaker panels.
I am needing inverter suggestions and recommendations on how to supply this much power to the home.
They want to get it off grid 100% and have battery backup as well.
I can't imagine how many we will need enough to supply a 30kw load if needed and
They are suing the local power company!!
the local company been messing them around will not change the meter. The meter is not reading correctly.
I give this customer credit they bought a sense for both panels and it's saying they're using less than half what our local company says and charges them for.
thank you all for your help & advice.
