Just designed & printed this case for the 8s 100A overkill BMS. (i used the Aliexpress version DJDD? for the template - hope there's no differences?)
There's 2-3mm between the heat spreaders & the case, i also use ASA/ABS to print with for heat resistance.
I'll be posting up on Thingyverse & email overkill so that others can print/use it.
Works well, goes together nicely, held with 4 screws together & the BMS is sandwiched at the screw holes. The whole thing also has 4 supports at corners to screw to a wall.
Issues - the small louvers are quite fragile as they're unsupported, i didnt want to do too much bridging. You could just use acetone & fuse them together at the top with some filament to increase strength though.
