kenkoh Solar Enthusiast Joined Jan 10, 2020 Messages 527 Location Las Vegas & Pennsylvania Feb 16, 2021 #1 Does Will have a video on this, anyone with a link?
mikefitz Solar Wizard Joined May 28, 2020 Messages 3,037 Feb 18, 2021 #2 Try putting your title into a search engine, Setting up the EPEVER Solar Charge Controller The Epever MPPT solar charge controller has become a popular option for many customer applications. Find out how to set it up here! battlebornbatteries.com Mike
kenkoh Solar Enthusiast Joined Jan 10, 2020 Messages 527 Location Las Vegas & Pennsylvania Feb 18, 2021 #3 mikefitz said: Try putting your title into a search engine, Setting up the EPEVER Solar Charge Controller The Epever MPPT solar charge controller has become a popular option for many customer applications. Find out how to set it up here! battlebornbatteries.com Mik mikefitz said: Try putting your title into a search engine, Setting up the EPEVER Solar Charge Controller The Epever MPPT solar charge controller has become a popular option for many customer applications. Find out how to set it up here! battlebornbatteries.com Mike Click to expand... Thanks Click to expand...
H Hiesenfig New Member Joined Feb 5, 2021 Messages 15 Feb 18, 2021 #4 There are two issues with the settings on that page. Per the EPEver manual: Equalize Charging Voltage Shutoff must be greater or equal to the Boost Charging Voltage. Low Voltage Reconnect must be great than the Low Voltage Disconnect.
kenkoh Solar Enthusiast Joined Jan 10, 2020 Messages 527 Location Las Vegas & Pennsylvania Feb 18, 2021 #5 Hiesenfig said: There are two issues with the settings on that page. Per the EPEver manual: Equalize Charging Voltage Shutoff must be greater or equal to the Boost Charging Voltage. Low Voltage Reconnect must be great than the Low Voltage Disconnect. Click to expand... Thanks. I found the WIll video I was looking for: Can someone confirm for me the 24v settings as: Temperature Compensation Coefficient = 0 Charge Limit Voltage = 29.2 volts Float Voltage = 27.2 volts Equalize Time = 0 Last edited: Feb 18, 2021
