T1nTodd
I'm trying to troubleshoot a battery that I built for a friend. I used four CATL 310ah cells and a daly 250 bms. She is getting 40v at her busbar intermittently. Battery has been working fine for 1.5 years. She is in Cali and I'm in Denver at the moment, so doing this via FaceTime and phone calls. She is using a cheap multimeter. Had her test individual cells via live video and all 4 cells are showing 3.35-3.40. Bms is shutting down every once in a while. Mostly at night. Her Aims 3000w inverter will beep with high voltage alarm. Bms gives high voltage alarm on daly bms app. Had her test the victron charge controller in and outgoing (batt and solar) with multimeter. 20v in and 13.6 out going. Over the past few weeks she has been getting 40v at busbar intermittently. I had her unplug inverter, bluesea fusebox, and victron 100-50 charge controller. Busbar then reads 13.6v. Plug everything back into busbar and magically busbar reads 13.6 and everything works for a day or two. Then high voltage alarms and bms shutoff come back. She borrowed a battleborn 100ah battery for a couple weeks. No issues for 4 days with battleborn. Plugged my battery back in and 2 days later she's getting high voltage alarm again and system shuts down. During 40v condition I had her measure voltage at busbar while she unplugged fuses and one of the fuses dropped the voltage at busbar to 3v. Plugging it back in and still at 3v till bms comes back on, then at 13.6v again. I'm stumped as the 40v condition is not permanent and I can't narrow it down. Thoughts on what to do next? Could it be an issue with my battery?
