Brucey
Solar Wizard
I would go chargeverter if you need more amps.
@NewGuy2330 amps@120v ac is NOT the same as 30 amps@48v dc
Haha , it's a little confusing do not worry , amps are relative
If you want to draw 15amps from your 120v AC power source
You would need between a 35a - 40a 48v charger
It's easier if you convert to watts
15a X 120v = 1800w
37.5a X 48v = 1800w
Different levels of volts and amps , the same amount of watts, the same amount of power
Yes, I understand. I don't think you read my original post correctly. Thanks for your advice.Haha , it's a little confusing do not worry , amps are relative
15amps from your 120v AC is 1,800w ?15 amps from the A/C, 120 volts
Do you think this one would work ok?Just get an EG4 Chargeverter.
You can set the voltage and amperage for whatever you want. It works on 120v or 240v.
It will, after you switch batteries.Do you think this one would work?
10-4, thanks again for you help. I'll just order the chargeverter. One more question if you don't mind? It says I need the cable adapter if I want to use a 120v supply, but I can't find that anywhere. Any idea?It will, after you switch batteries.
I wouldn't use it for lead acid.
The Chargeverter is more versatile. Because it has full adjustability.
It doesn't exist.10-4, thanks again for you help. I'll just order the chargeverter. One more question if you don't mind? It says I need the cable adapter if I want to use a 120v supply, but I can't find that anywhere. Any idea?
Thanks again, I really appreciate it! ?It doesn't exist.
You can just replace the cord end.
Brown = line (hot)
Blue = neutral
Yellow/ green stripe = ground
Do youThanks again, I really appreciate it! ?
Do you think I'm good to run this to my ground bus bar, or should I give it its own grounding rod?It doesn't exist.
Brown = line (hot)
Blue = neutral
I just ordered it. Not cheap. I hope it does what I need it to!It doesn't exist.
Brown = line (hot)
Blue = neutral
One grounding system for everything.Do you
It will be the most awesomest charger you ever bought.I just ordered it. Not cheap. I hope it does what I need it to!
I guess I should have asked if you sold them first, but I assume you would have offered if you did. Thanks again.It will be the most awesomest charger you ever bought.
Not affiliated.I guess I should have asked if you sold them first, but I assume you would have offered if you did. Thanks again.
