Hey thank you for this. So I have used my little 30v/10a charger (that I got for drone bench work). I also bought a 2nd one on amazon because figured charging each cell would take a while.
So I am not sure if I am doing something wrong at this point. When I put my drone one (little tiny ToolkitRC P200).. on the battery which is at 3.0v.. the amp jumps to 9.8. I set the V to 3.4. These LEV60 seem to top out at 3.5 if I am reading things right, so I assume I do NOT want to go past 3.5v on the power supply? Like can I do 3.7 to push it a little faster charging until the battery itself is up to about 3.4v, then dial the V back down to 3.5? Or is anything over 3.5 out of the bench supply going to damage the battery?
Anyway, it took about 3 to 4 hours to get one cell from 3.0 to 3.3v. Around 3.3 to 3.35 or so. I was thinking I would get all 16 cells to 3.3v exactly, then build the 48v battery with the BMS, etc. BUT.. you said get them all to 3.45 or so before I do that? So basically I would set the power to 3.5v, and just let it run for about 10 hours or so for each cell... checking every hour or so to see where it is at? I am using my Fluke multimeter which has 4 places of accuracy apparently, so hopefully given the insane expense of that multimeter and the name, it's pretty accurate.
So does that seem right? I think I read/saw that as you near the top of the V (in my case 3.45 or 3.5 maybe?) the amp will go down to < 1 amp. But here is the thing. On the amazon 30v/10a bench supply, it was at <1a when the battery was around 3.25v. In fact, my little tiny TookitRC was charging quite a bit faster than the other one.. so I guess that little thing at about 2x the price is indeed using some good components vs the china $50 one I got.. because it was taking a few hours more to go from 3.25v to 3.3v or so.
So I saw Prowse video on putting all 16 cells in parallel, and he said it should only take a few hours using that cheap bench supply (I got the same one he did) to charge all 16 up.. and yet.. I can't seem to get it to charge a single cell in hours.. so am I doing something wrong, or does parallel charging work about the same speed as a single cell?
My concern is these LEV60 (
https://jag35.com/products/high-discharge-600a-lifepo4-1780w-prismatic-cells?variant=40806504398963) are 3.5max.. so is setting the supply to 3.5 ok or is there a risk of damaging them at that setting? More so.. given that I charge each of the 16 cells to 3.3v and they all dropped to 3.28 to 3.30 after a couple hours.. I don't know how the hell I will know if they are actually top balanced.. because if I get one to 3.5 or 3.45.. and then move the bench supply to another, that first one is going to drain a bit.. so how do I get them all accurate together to then assemble and finally put on the inverter charger so that each night that thing can charge them up? I know the 100a BMS that Jehu uses has balancing on it.. I believe on both charge and discharge.
The other concern is.. I did read that from time to time the batteries can somehow get out of balance again. So how the hell do you know this? I am all in on the Victron stuff, and I'd buy one of those $130 or or so battery shunts if that is a good way to be able to know, but that seems like its for the whole 48v pack, not individual cells. So do I have to check the display on the battery like every few days for ever.. or is this something that happens over the course of a year or so? Assuming it does.. do I now have to disassemble the battery each time, pull the cells out, charge them again, etc? Like given they are LiFePo4 and there is a BMS.. I assumed once they are set, that's it.
Lastly (probably again).. but I am still not clear if either these cells (Because they are 3.5 not 3.65.. are they different) can go from 0 to 100 to 0 over and over.. or if I should set my Victron inverter/charger to charge at 20% (or 10%?) and stop at 80% or 90%? I want to maximize the cells.. and given that we seemingly have to top charge(balance) them to like 99% capacity before using.. not sure if that means to keep them all balanced we always have to charge to 99% or so each day so that the BMS can ensure they stay balanced?
Again thank you for all the info. Excited to get this damn battery in use! I have everything (but the cells) to build a 2nd one and want to get that in place soon as well.
