I've noticed that the MPP 6000 series and Growatt 5000ES and a few other Growatt models recommend a battery sizing of 200Ah (10.24KWh = 200ah*51.2v) per inverter. Does anyone know what is the basis of this recommendation? When I run the numbers, the 200Ah recommendation seems oddly low. For example, assuming 5 hours sunlight and a 5000ES inverter, assuming 90% overall efficiency that's a total of 5000w*5*0.9 = 22.5kw which equates to approx 400Ah. Is MPP's and Growatt's assumption that the amount of solar I am generating, that 50% of it is being used for my load and the other 50% used to charge the batteries? And if that's the case, if during sunlight hours my load only consumes 10% of solar generated, will it be safe to have a higher Ah battery on these inverters seeing that 90% of solar generated is being unused and can therefore go to charging the batteries (given the charging amps capacity of the inverter of course)? For my power utilization scenario (and I suspect for alot of other folks) my power usage is much higher at night than during the day. Thanks in advance.
