rustythorn
hypothetically theoretical
another option if you plan to have continuous 120VAC in your setup is to use some premade items like this on at 35F off at 45F, however, there are various temp range options out there
If you have 120v (from the inverter) handy - what about using a 120v Inkbird temperature controller- it has 10a relays (both heat & cool).
Then you are using cheap 120v stuff and if your batteries get low the inverter shuts (everything) down - don’t have to worry about a heater draining the battery during a snowstorm in the winter.
Good Luck
I fitted a 48v to 12v convertor, and then used a pair of these.
The 48v to 12v converter fed the two relays on the cerbo with 12v, that then fed back to the control side of the SSR (solid state relay), the SSR then switched 48v to my heater pads, which are actually two 24v truck mirror heater pads in series.
This worked perfectly last winter, although it doesn't get cold here really, heating only came on a few times.
It all got a bit messy, and I currently have it all ripped out as I needed the space to add two more MPPT's.
I'll revisit the heating system once I've finished my solar upgrades.
Is this a Normally Open or Normally Closed relay
I haven't been following this thread recently, but I have to say I'm not sure why the solution seems to be getting complicated.
The 48V system I helped spec and install used a single 48V to 12V buck converter (https://www.amazon.com/dkplnt-Converter-Transformer-DC-DC-Non-Isolated/dp/B089FZMN5G), which powered only the 12V thermostat that many folks here use (including @HRTKD, I think?): https://www.amazon.com/LM-YN-Thermostat-Fahrenheit-Temperature/dp/B076Y5BXD9
Then I used the 48V from the system to go through the thermostat relay to power 4 12V 10W heating pads connected in series. I can't find these pads on Amazon now, but they are probably there. These pads in series pull less than 1A @ 48V, so the thermostat relay can handle it directly. I put the four pads on the sides of the two Trophy batteries. This worked great through last winter in the mountains.
There are tons of 12VDC heater pads, and connecting four in series will allow you to spread them around a bit to cover more area. I experimented with several for my 24V 8S pack, and found that a couple of the little 12V 12W pads were perfect.
was the relay on the thermostat rated for 48v DC?
