Good morning.
Looks like you are using battery communication. Fault 58 is related to BMS comm issues, not sure what fault 59 is.
I'd recommend disconnecting the communication cable and trying these settings, they've been working great for me.
LV5048 4 SunPower 320W panels (2s2p) 4 SunPower 420W panels (2s2p) 4 SunPower 420W panels (4p) (i was scammed on those 420W panels. only 4 work and output about 350W that i have seen. other 4 shows full voltage but when connected it outputs only 1/3 or 1/2 output) 6 100AH rackmount LifeP04...
diysolarforum.com
Note - you may need to reduce setting 07 depending on how big your battery bank is.
